problema esportazione dati
luca.spiz83
ciao a tutti, ogni volta che provo ad esportare un attività in qualsiasi formato, il programma si impianta sempre...suggerimenti su come poter risolvere il problema?
Re: problema esportazione dati
Verifichi di avere l'ultima versione del software.
Se il problema persiste, ci contatti all'indirizzo real@elite-it.com
Right click on the feature class in the table of contents, and click Properties. Click the Fields tab.
De-select the fields that have the problem field types.
Export the feature class to a shapefile mybkexperience.
Hello I have a trouble with the export of data : My users which are not admin of the workspace can't export all the rows, their export is cut
tommyshelby
The data export problem is happening with me as well on my iTunes as I am trying to export the data from the iTunes to other devices and the thing is that the data sharing has to be fixed and many users like me are having the issue.
