problema esportazione dati
luca.spiz83
Postby luca.spiz83 » Thu Nov 08, 2018 9:29 pm
ciao a tutti, ogni volta che provo ad esportare un attività in qualsiasi formato, il programma si impianta sempre...suggerimenti su come poter risolvere il problema?
Re: problema esportazione dati
Postby Elite Admin S » Fri Nov 16, 2018 12:37 pm
Verifichi di avere l'ultima versione del software.
Se il problema persiste, ci contatti all'indirizzo real@elite-it.com
Ronald309
Postby Ronald309 » Sat Jan 12, 2019 11:54 am
Right click on the feature class in the table of contents, and click Properties. Click the Fields tab.
De-select the fields that have the problem field types.
Export the feature class to a shapefile mybkexperience.
Ronald309
Postby Ronald309 » Thu Jan 17, 2019 11:27 am
Hello I have a trouble with the export of data : My users which are not admin of the workspace can't export all the rows, their export is cut
tommyshelby
Postby tommyshelby » Mon Mar 11, 2019 7:28 am
The data export problem is happening with me as well on my iTunes as I am trying to export the data from the iTunes to other devices and the thing is that the data sharing has to be fixed and many users like me are having the issue.
Return to “Software Real”
