Misuro B+ Novo force
Jacob518
Postby Jacob518 » Sat Feb 02, 2019 10:13 am
Misuro B+ problem
I have Misuro B+ and a Elite Novo Force 8. When I setup speed and cadence (iOS or McDVOICE) I keeps getting “No data” or invalid invalid information.
Any idea?
Same sensor and turbo trainer . i seem to be getting rpm data but no watts . also the avatar on the screen never moved .
potagi
Re: Misuro B+ Novo force
Postby potagi » Fri Jul 26, 2019 1:12 pm
nice one njmcdirect thanks for sharing
daniel.syguides
Postby daniel.syguides » Tue Dec 05, 2023 4:04 am
If you're encountering "No data" or invalid information with Misuro B+ and Elite Novo Force 8, ensure that the sensors are correctly installed and paired. Check the battery levels, position, and alignment of both speed and cadence sensors. Verify arbys hours compatibility between Misuro B+ and your specific trainer model, and consult the product manual for any troubleshooting steps. If issues persist, contacting the manufacturer's customer support for dedicated assistance would be advisable.
lawleitl22
Postby lawleitl22 » Wed Apr 17, 2024 2:16 pm
https://spotsurv.com/
Nice post. I was checking constantly this blog and I am impressed! Extremely helpful information especially the last part I care for such info a lot.
Thank you and good luck.
Return to “Misuro”
