Misuro B+ problem
I have Misuro B+ and a Elite Novo Force 8. When I setup speed and cadence (iOS or McDVOICE) I keeps getting “No data” or invalid invalid information.
Any idea?
Same sensor and turbo trainer . i seem to be getting rpm data but no watts . also the avatar on the screen never moved .
Misuro B+ Novo force
Re: Misuro B+ Novo force
nice one njmcdirect thanks for sharing
daniel.syguides
If you're encountering "No data" or invalid information with Misuro B+ and Elite Novo Force 8, ensure that the sensors are correctly installed and paired. Check the battery levels, position, and alignment of both speed and cadence sensors. Verify arbys hours compatibility between Misuro B+ and your specific trainer model, and consult the product manual for any troubleshooting steps. If issues persist, contacting the manufacturer's customer support for dedicated assistance would be advisable.
lawleitl22
https://spotsurv.com/
Nice post. I was checking constantly this blog and I am impressed! Extremely helpful information especially the last part I care for such info a lot.
Thank you and good luck.
Users browsing this forum: Baidu [Spider] and 31 guests
