Squeak on startup
andrewjbegg
Squeak on startup
Postby andrewjbegg » Mon May 09, 2022 2:49 pm
Here's a video of a squeak I have on start up.
Can this be resolved or will the trainer need to go back to Elite?
https://thumbsnap.com/55eNEY31
Re: Squeak on startup
Postby Elite Admin S » Tue May 10, 2022 7:58 am
It's necessary to add some grease to the motor screw.
Follow these instructions:
- run my e-training app (smartphone or tablet)
- select level mode
- set the level to 16 to free the motor screw
- clean the motor screw using some paper tissue
- add some vaseline grease on the screw using a little brush
- move the level from 16 to 1 few times to spread the grease all over the screw
This should solve the problem
andrewjbegg
Postby andrewjbegg » Wed May 11, 2022 1:43 pm
That worked. Thank you.
nuno_fpinto
Postby nuno_fpinto » Wed May 18, 2022 9:23 am
Wow..having the same issue every time i turn the trainer on. Will try This.
nonatoman
Postby nonatoman » Sun Jan 29, 2023 6:14 pm
I had the same issue. This worked perfectly. Thank you.
Just to clarify for anyone else that has this issue: I only had to take the plastic panel on the non drive side of the trainer that was held together by 4 screws.
mayomayo72218
Postby mayomayo72218 » Fri Oct 27, 2023 6:55 am
Quick Draw
emmausa
Postby emmausa » Mon Dec 11, 2023 7:36 am
good
kezb81
Postby kezb81 » Sat Dec 23, 2023 8:04 pm
Thank you that worked perfectly! And saved me the worry of having to buy a new turbo trainer at the wrong time of year! :D
etiennep13
Postby etiennep13 » Sun Jan 07, 2024 4:28 pm
je n'ai pas trouvé comment passer du mode 16 à 1 dans l'application my etraining comme vous l'expliquez. pouvez-vous donner plus de précision sur ce qu'il faut faire ?
timothyferriss
Postby timothyferriss » Sat Sep 21, 2024 3:52 am
It worked. Thank you.1v1 lol
