Here's a video of a squeak I have on start up.
Can this be resolved or will the trainer need to go back to Elite?
https://thumbsnap.com/55eNEY31
Squeak on startup
Re: Squeak on startup
It's necessary to add some grease to the motor screw.
Follow these instructions:
- run my e-training app (smartphone or tablet)
- select level mode
- set the level to 16 to free the motor screw
- clean the motor screw using some paper tissue
- add some vaseline grease on the screw using a little brush
- move the level from 16 to 1 few times to spread the grease all over the screw
This should solve the problem
- select level mode
andrewjbegg
That worked. Thank you.
nuno_fpinto
Wow..having the same issue every time i turn the trainer on. Will try This.
I had the same issue. This worked perfectly. Thank you.
Just to clarify for anyone else that has this issue: I only had to take the plastic panel on the non drive side of the trainer that was held together by 4 screws.
mayomayo72218
Quick Draw
Quick Draw
Thank you that worked perfectly! And saved me the worry of having to buy a new turbo trainer at the wrong time of year!
etiennep13
je n'ai pas trouvé comment passer du mode 16 à 1 dans l'application my etraining comme vous l'expliquez. pouvez-vous donner plus de précision sur ce qu'il faut faire ?
timothyferriss
It worked. Thank you.1v1 lol
