Direto XR hard resistance at the start.
costantini24
Re: Direto XR hard resistance at the start.
Postby costantini24 » Sun Nov 27, 2022 9:49 am
Same issue here, bought 1 month ago.
Thinking on replacing it.
heiko
Postby heiko » Mon Dec 12, 2022 11:47 pm
same issue, firmware 078 and using a Garmin Edge 530 to control the trainer.
Support claims it‘s normal which is clearly not true.
i upgraded from a Direto (first generation) but i regret it
fernulv
Postby fernulv » Thu Dec 22, 2022 4:01 pm
Hi.
I opened the chassi to have a look at the screw that adjustes the break. I started E-Training and went from lvl 1-16 without problem, but when going back to lvl 1 it kind of got stuck halfway. So it said lvl1 in the program but breakes still on.
So, I cleaned of all the vaseline from the screw with drivetrain cleaning. After that it worked for me. Have just tried it once with Zwift so I cant be certain, but it doesent get stuck anymore, due to old, grease gone sticky.
good luck
mayomayo72218
Postby mayomayo72218 » Fri Jul 21, 2023 10:14 am
Looks like Direto XR has more bugs than it promised!
Super Mario
harri.ilmari.toivonen
Postby harri.ilmari.toivonen » Tue Sep 19, 2023 12:13 pm
Firmware update 78->80 removed my start resistance and ERG problems totally - now it's working as it should - for a while....
muzza1
Postby muzza1 » Mon Oct 02, 2023 10:16 pm
My trainer has only just started doing this after being fine for many months.
It's when I start a training plan/module - it will remain at way past my FTP and it won't come right unless I pause/restart the ride 2-3 times (using the companion app in Rouvy).
Is this a firmware thing?...or is something about to fail?
Murray
heiko
Postby heiko » Sat Oct 07, 2023 1:17 pm
muzza1 wrote:My trainer has only just started doing this after being fine for many months.
Murray
It is for sure a software problem, but Elite tends to deny the existence.
Did you already update to firmware v80? If you are lucky this is a solution.
Users browsing this forum: Bing [Bot] and 27 guests
