Same issue here, bought 1 month ago.
Thinking on replacing it.
Direto XR hard resistance at the start.
costantini24
Re: Direto XR hard resistance at the start.
same issue, firmware 078 and using a Garmin Edge 530 to control the trainer.
Support claims it‘s normal which is clearly not true.
i upgraded from a Direto (first generation) but i regret it
Hi.
I opened the chassi to have a look at the screw that adjustes the break. I started E-Training and went from lvl 1-16 without problem, but when going back to lvl 1 it kind of got stuck halfway. So it said lvl1 in the program but breakes still on.
So, I cleaned of all the vaseline from the screw with drivetrain cleaning. After that it worked for me. Have just tried it once with Zwift so I cant be certain, but it doesent get stuck anymore, due to old, grease gone sticky.
good luck
good luck
mayomayo72218
Looks like Direto XR has more bugs than it promised!
Super Mario
Super Mario
harri.ilmari.toivonen
Firmware update 78->80 removed my start resistance and ERG problems totally - now it's working as it should - for a while....
My trainer has only just started doing this after being fine for many months.
It's when I start a training plan/module - it will remain at way past my FTP and it won't come right unless I pause/restart the ride 2-3 times (using the companion app in Rouvy).
Is this a firmware thing?...or is something about to fail?
Murray
Murray
muzza1 wrote:My trainer has only just started doing this after being fine for many months.
Murray
It is for sure a software problem, but Elite tends to deny the existence.
Did you already update to firmware v80? If you are lucky this is a solution.
Users browsing this forum: Bing [Bot] and 27 guests
