Direto resistance very high
blaircabot
Postby blaircabot » Sat Feb 24, 2018 4:01 pm
I got a Direto last week and have been having problems with the resistance. It is very high and will not change. Pedaling in the easiest gear at 70rpm is 220 watts.
It pairs to the My ETraining app and calibrate well (although it's hard to do with such a high resistance). In the app using the + and - to change resistance does not make a difference.
Using it with Zwift and my Garmin 520 is the same, very high resistance and it doesn't change at all. Anyone else have a similar problem?
Re: Direto resistance very high
Postby Elite Admin S » Wed Mar 21, 2018 12:46 pm
I see that you've already solved the problem with our customer care (there was a problem on the electronic board)
joakimlindholm1
Postby joakimlindholm1 » Thu Jun 21, 2018 9:03 pm
I have a similar problem. The trainer worked for the first 5 minutes but then got stuck at a very high resistance. When I decrease power in the elite app, nothing happens. Any idea on how to fix this?
Kind Regards!
Joakim
Postby Elite Admin S » Mon Jun 25, 2018 11:25 am
@joakimlindholm1,
Contact the customer care at myetraining@elite-it.com (it's necessary to investigate further)
Users browsing this forum: Bing [Bot] and 64 guests
