Map Courses feature. Spikes in elevation.
TweekySenior
Postby TweekySenior » Fri Apr 17, 2020 5:56 pm
Since the last software update, after uploading KML files as a Map Course I'm seeing little 'spikes' in elevation on the route profile that obviously are not 'real'. (see attached example screenshots). These spikes are usually significant in gradient and whilst you might expect to go from 5% to 13% whilst climbing hitting a 15% ramp on a 5/6/7% descent whilst thrashing your 50/11 gear is a bit of an issue.
To narrow down where the problem is I have created KML files s using different file converters and reviewed the same KML files using different KML viewers and it is only when they are imported in to My e-training that the spikes are created.
Anyone have any ideas? Is it just a bug in My e-training?
I'd like to get rid of the issue as it is a real irritation.
example 2.jpg (154.68 KiB) Viewed 17625 times
example 1.jpg (174.38 KiB) Viewed 17625 times
Re: Map Courses feature. Spikes in elevation.
Postby Elite Admin S » Thu May 21, 2020 11:23 am
It's the first time I see something like that honestly.
Can you tell me exactly the start and stop points so I can do some test?
rlusitano
Postby rlusitano » Wed Aug 05, 2020 4:24 pm
I have the same problem....
is there a solution???
thanks
geolulu
Postby geolulu » Wed Dec 08, 2021 9:17 pm
Io ho lo stesso problema, è per caso stato risolto? Confermo che la cosa avviene solo in MYtraining, ho verificato effettuando diversi tipi di smoothing del dato con vari software e con excel.
pasqudef
Postby pasqudef » Sun Dec 19, 2021 11:03 pm
Dear all,
I've faced the same issue (spikes in the elevation); i've maked some test with different website to make the conversion from gpx to kml. The spikes was solved using mygeodata website --> https://mygeodata.cloud/converter/gpx-to-kml .
Ciao a tutti,
Ho avuto lo stesso problema (picchi nell'altimetria); ho fatto alcuni test con diversi siti web per fare la conversione da gpx a kml. I picchi sono stati risolti usando il sito mygeodata --> https://mygeodata.cloud/converter/gpx-to-kml
elevetion spikes.png (246.05 KiB) Viewed 15636 times
armandopretto
Postby armandopretto » Fri Jan 14, 2022 5:16 pm
Stesso problema anche per me. Esportato la traccia GPS da Garmin e convertito file GPX in KML.
Quando poi importo il percorso in My e-training sul tracciato appaiono picchi di altezza assolutamente inesistenti, e moolto fastidiosi per la pedalata.+
per togliermi la sfizio ho esaminato i dati originali GPX e quelli convertiti KML, e i valori dell'altitudine sono assolutamente lineari, senza sbalzi.
verifica dati.xlsx
(128.05 KiB) Downloaded 1401 times
verifica spikes.png (53.22 KiB) Viewed 15230 times
pbanders@yahoo.com
Postby pbanders@yahoo.com » Wed Mar 02, 2022 3:55 pm
Another solution is to use GPX Smoother to remove the spikes before the KML conversion.
https://www.potter.ca/Biking/smoother/gpxsmoother.html
