Peronaoized Training Programmes
bird.rabbie
Postby bird.rabbie » Mon Mar 23, 2020 9:57 pm
The Instructions fo the Elite Zumo says that with the My E-Training app, you can set up personalised training programs. I have downloaded the app, but I can't find how you can set up a personalised training session.
Anyone got a step by step guide?
Thanks in advance. Robert B.
Jonalbert
Re: Peronaoized Training Programmes
Postby Jonalbert » Tue Apr 07, 2020 11:25 pm
bird.rabbie wrote:The Instructions fo the Elite Zumo says that with the My E-Training app, you can set up personalised training programs. I have downloaded the app, but I can't find how you can set up a personalised training session.
peryourhealth.com
Did you find any good solution? It seems I faced the same problem here.
stein.b.iversen
Postby stein.b.iversen » Wed Apr 22, 2020 9:39 am
Start the Elite myETraining app and perform the "Training Test".
After the test is completed the app will make a training program based on the results from the test.
Good luck!
Regards Stein
Postby Elite Admin S » Fri Apr 24, 2020 5:25 pm
To create a training, you have to open the workout session and select program mode.
There you can create all the type of trainings you need (power/time, power/distance, slope/time...)
