The Instructions fo the Elite Zumo says that with the My E-Training app, you can set up personalised training programs. I have downloaded the app, but I can't find how you can set up a personalised training session.
Anyone got a step by step guide?
Thanks in advance. Robert B.
Peronaoized Training Programmes
Re: Peronaoized Training Programmes
bird.rabbie wrote:The Instructions fo the Elite Zumo says that with the My E-Training app, you can set up personalised training programs. I have downloaded the app, but I can't find how you can set up a personalised training session.
peryourhealth.com
Did you find any good solution? It seems I faced the same problem here.
stein.b.iversen
Start the Elite myETraining app and perform the "Training Test".
After the test is completed the app will make a training program based on the results from the test.
Good luck!
Regards Stein
Good luck!
Regards Stein
To create a training, you have to open the workout session and select program mode.
There you can create all the type of trainings you need (power/time, power/distance, slope/time...)
