My trainer has started squeaking really loudly, it’s almost like it needs to be greased or oiled.
I can’t find any maintenance info on this.
Anybody know if you are suppose to oil/grease and if so how?
Trainer is only 11months old.
Stuart
Loud Squeaking Elite Qubo Digital Smart B Plus Trainer
stuartcheverton
andrernascmento
Re: Loud Squeaking Elite Qubo Digital Smart B Plus Trainer
Mine have the same issue with 16 months of use, according to Elite my resistance unit needs to be replace as there is no way to fix it.
@stuartcheverton,
contact the customer care at myetraining@elite-it.com.
It's probably a mechanical issue.
