Loud Squeaking Elite Qubo Digital Smart B Plus Trainer
stuartcheverton
Postby stuartcheverton » Thu Nov 07, 2019 9:11 pm
My trainer has started squeaking really loudly, it’s almost like it needs to be greased or oiled.
I can’t find any maintenance info on this.
Anybody know if you are suppose to oil/grease and if so how?
Trainer is only 11months old.
Stuart
andrernascmento
Re: Loud Squeaking Elite Qubo Digital Smart B Plus Trainer
Postby andrernascmento » Wed Nov 13, 2019 9:27 pm
Mine have the same issue with 16 months of use, according to Elite my resistance unit needs to be replace as there is no way to fix it.
Postby Elite Admin S » Fri Nov 15, 2019 11:21 am
@stuartcheverton,
contact the customer care at myetraining@elite-it.com.
It's probably a mechanical issue.
