Issue with cassette 11 speed sram 11-42
etienne.delobbe
Postby etienne.delobbe » Thu Mar 18, 2021 9:09 pm
Hi all,
I have bought a suito this week and a cassette Sram pg1130.
When I read the notice no spacer is needed for 11 speed cassette.
Nevertheless without a spacer the cassette is not totally blocked so I can’t used the home trainer.
Can you please explain how to solve this issue ?
Best regards
Etienne
red.hell
Re: Issue with cassette 11 speed sram 11-42
Postby red.hell » Thu Mar 18, 2021 10:11 pm
11v road cassette is longer than 11v mtb cassette, that's equal to a 10v mtb and road cassette
so to work correctly with a 11v mtb cassette spacer is needed
etienne.delobbe
Postby etienne.delobbe » Fri Mar 19, 2021 8:54 am
Red.hell, thanks for your reply !
ymarti.ymarti
Postby ymarti.ymarti » Fri Mar 19, 2021 12:39 pm
HI!
I have Suito and a MTB with Sunrace 11-42 11 speed
Spacer used. It works perfectly!
Ciao!
GOD SAVE THE RIDER
etienne.delobbe
Postby etienne.delobbe » Fri Mar 19, 2021 1:46 pm
Thanks ymarti, you used 1 or 2 spacers ?
ymarti.ymarti
Postby ymarti.ymarti » Sun Mar 21, 2021 2:32 pm
1 (only one)
ciao!
GOD SAVE THE RIDER
andradematthew0
Postby andradematthew0 » Tue Sep 28, 2021 1:34 pm
etienne.delobbe wrote:Thanks ymarti, you used 1 or 2 spacers ?
I Etienne, I have a PG1130 cassette and have used 1 x spacer. The cassette now seems solid, but I get chain rub. Did you need to make any other changes to your bike setup when putting on the Suito?
red.hell
Postby red.hell » Wed Sep 29, 2021 11:09 pm
for me 2 spacer are needed, the length different between 10v and 11v road is 1,85 mm
with double spacer I had only to make small regulation on the transmission
szelusz
Postby szelusz » Mon Feb 03, 2025 6:45 pm
When I install the sleeve the all casette is going outside and the derailer cannot reach the smallest rack.
Do you have the same issue?
Piotr
Return to “Suito”
