Good Morning
I have the direto xr and the fenix 5. I paired both but in the fenix I have a very high speed. I only want to use it to register the activity, not to simulate.
Do you know if i have to do something different to get the correct data?
Direto XR t and Fenix 5
Re: Direto XR t and Fenix 5
I suppose that you connect the trainer as a speed&cadence sensor plus a power sensor.
This means that you have to set a circumference value considering the internal ratio of the trainer:
https://elitesrl.zendesk.com/hc/en-us/a ... -Elite-app
That said, I'm not sure that Fenix 5 allows to set a customize circumference value.
Check the device user manual
ymarti.ymarti
Checks my post. i have fenix 5 and an Elite Suito. I have shared my experience: it is necessary to set the right circumference value!
GOD SAVE THE RIDER
jesusgarciapedro
Elite Admin S wrote:Hi
Thanks, with this url i have set right my fenix
Users browsing this forum: No registered users and 157 guests
