Suito mechanical issue
john6cartwright
Postby john6cartwright » Fri Aug 06, 2021 12:48 pm
I was using my Suito yesterday when the middle bolt of the 3 on the bottom plate came out.
I have a picture but cannot seem to upload it?
Is the suito still OK to use without this bolt in place?
Or do I need to take the machine apart to put the bolt back in place?
Re: Suito mechanical issue
Postby Elite Admin S » Fri Aug 06, 2021 12:54 pm
I suggest you to contact the support adding a photo of the hole and bolt.
The guys there will tell you what to do.
Users browsing this forum: No registered users and 154 guests
