Elite Suito Garmin Connect
stijn.minne
Postby stijn.minne » Thu Apr 15, 2021 8:03 am
Hello everyone,
I have been using Garmin Connect and a Garmin watch for all my sport activities for years.
Recently I purchased a Elite Suito, I was told this could be connected to Garmin Connect as well.
I have not been able to connect though. Does anyone know how to or have any tips?
Many thanks!
My best regards,
S
ymarti.ymarti
Re: Elite Suito Garmin Connect
Postby ymarti.ymarti » Thu Apr 15, 2021 8:29 am
If you select Bike Indoor activity you will see all devices connected properly in your watch.
Enjoy
PS: make attention to wheel circumference...
GOD SAVE THE RIDER
Postby Elite Admin S » Thu Apr 15, 2021 10:25 am
About circumference and speed, here's a useful link:
https://elitesrl.zendesk.com/hc/en-us/a ... party-apps
jk.chik
Postby jk.chik » Mon Apr 19, 2021 8:49 pm
My 530 edge connected with no problems (via ANT+) to my Suito. J
phigen
Postby phigen » Wed Feb 09, 2022 9:34 am
My Garmin Forerunne 745 can see my Suito in 3 modes :
- Puissance,
- Vit/cad,
- Trainer.
May I connect to the 3 captors ?
Thank you.
Postby Elite Admin S » Thu Feb 10, 2022 8:52 am
To have the resistance control, you have to pair it as trainer.
If you want only to see the data, without control (for example if you are controlling the resistance using another device or application), you can pair it as a speed&cadence sensor plus a power sensor
olialexlohnath
Postby olialexlohnath » Sat Nov 12, 2022 7:31 pm
Elite Admin S wrote:Hi
I have the same question but for my watch fenix 5X and justo:
I see -vit/cad 175
-puissance justo
-puissance 175
what do i have to connect for just save the activity on garmin connect?
When you write "have the resistance controle" you mean that it's possible to create exercices from garmin connect for use on suito?
Thank You.
Postby Elite Admin S » Mon Nov 14, 2022 8:05 am
If I'm right, Fenix 5 doesn't support interactive trainers. This means that you cannot control the trainer resistance, you can only pair it as it was an external speed&cadence sensor plus a power sensor.
