Replacement 142x12 attaining nut
rxtaylor.misc
Postby rxtaylor.misc » Fri Apr 09, 2021 11:27 am
Can anyone help with where I can get a replacement nut for the Directo trainer. The original was quite a soft metal and has been damaged changing over the cassette.
I have looked online but can’t find anywhere that has the 142x12 one
hernandez_christ
Re: Replacement 142x12 attaining nut
Postby hernandez_christ » Fri Apr 09, 2021 8:21 pm
You should contact the support directly. They will surely have spare parts for you.
Postby Elite Admin S » Mon Apr 12, 2021 9:35 am
If you mean the rotating nut of the Direto XR, you can find it here:
https://www.shopelite-it.com/en/sensors ... -direto-xr
If you have a Direto or a Direto X instead contact us from here:
https://support.elite-it.com/
