updating roadmap
ymarti.ymarti
updating roadmap
Postby ymarti.ymarti » Wed Feb 24, 2021 2:35 pm
I think that this app works well paired with my Suito. I'm a new user.
Yesterday I tried to rode the alpe d'huez with realvideo: it was amazing! Compliment to elite!
But could be useful to have a direct integration with Garmin Connect in order to have an unic point to collect all data (e.g. training load with elite data collected)?
At the moment I connected my e-training app with all suito's sensors.
I started the activity
I started the garmin indoor activity with only a cadence sensor (if I connect also power sensor with garmin some trouble will occour)
At the end the elite app reconize automatically end of activity. I stopped activity on garmin.
I exported the activity on Garmin Connect
Now I have two activity (= the same).
The dream should be to have a unique activity! could be possible to have a forecast in order to know the updating? :-)
Thank you for the kind feedback
marti
GOD SAVE THE RIDER
hernandez_christ
Re: updating roadmap
Postby hernandez_christ » Thu Feb 25, 2021 9:20 am
Hi Marti
After your ride on your home trainer, go in your history on my e training and export as gpx. Then go on connect.garmin website and import your ride. You won't have any GPS or altimeter data but rest is fine (cadence, power, heart).
And elite is not very answering about road map.
Ride safe
Chris
ymarti.ymarti
Postby ymarti.ymarti » Thu Feb 25, 2021 11:15 am
Thank you Chris,
I exported the file as tcx. But in that case the training effect is not calculated.
The other choice are:
export as csv
export as tcx
export as fit
upload directly to strava
upload directly to mapmyride
upload directly to trainingpeaks
Maybe is possible to combine manually the activities after exporting...any idea? ;-)
Thanks a lot once again. Really appreciated!
marti
GOD SAVE THE RIDER
hernandez_christ
Postby hernandez_christ » Thu Feb 25, 2021 10:35 pm
I think garmin would need the altitude info to compute the TSS and this is not exported, whatever the format you choose I think.
The only solution would be if elite improve the app.
Edit: I'm now testing rouvy with the voucher and it exports all possible info, and garmin read everything nicely. But still the TSS is not given. I feel garmin will compute it only for the activities it will record directly (same as for the breathing frequency for instance)
ymarti.ymarti
Postby ymarti.ymarti » Fri Feb 26, 2021 11:06 am
I agree with you
Thanks for all.
It is necessary that Garmin and Elite will sign an agreement :-)
Ciao
GOD SAVE THE RIDER
Users browsing this forum: No registered users and 122 guests
