Elite TUO ERG mode stop working
ekirock
Postby ekirock » Tue Feb 16, 2021 2:03 pm
I bought an Elite TUO in december. It was working fine on Zwift until this week. Now ERG mode no more work so when the hill increase or decrease, the resistance doesn't change. So in high increasing hill the power is totaly crazy, like 600w as i am pushing like 100w...
I tried to do again a calibration, no change, check with upgrapdo I'm up to date, try with MyElite app and same problem...
Any idea ? Really disapointed...
hernandez_christ
Re: Elite TUO ERG mode stop working
Postby hernandez_christ » Tue Feb 16, 2021 3:04 pm
You should contact the support. Several of us got the same on different home trainer and the motherboard was said to be broken and they send us a spare board. I'm yet to receive mine but hopefully it will work.
carlanga24
Postby carlanga24 » Wed Feb 17, 2021 6:42 pm
Hi Christ Hernandez:
I have same issue; could you please share how did you get in contact with support? Was via email or by phone? I haven seen any contact number on the web site. I sent email couple days ago and I haven’t received any answer or advise yet.
Any information I will greatly appreciate it
hernandez_christ
Postby hernandez_christ » Wed Feb 17, 2021 9:25 pm
Hi Carlanga,
From the following page : https://support.elite-it.com/en you can search for your trainer. For you tuo then, and at the end of the page is a link to the ticketing page : https://support.elite-it.com/en/ticket
Usually they reply the day after, I guess they work on support in the morning.
I got the motherboard yesterday and I installed it right away. It works perfectly now.
carlanga24
Postby carlanga24 » Fri Feb 19, 2021 4:03 pm
Thanks a lot Chris, I will do it today...how long took to get the motherboard?...I’m glad to heard that you get the problem resolved
hernandez_christ
Postby hernandez_christ » Fri Feb 19, 2021 8:36 pm
Hi Carlanga
I guess from the first email it took maybe two weeks. Maybe one week of exchange by email (2-3 mails) and then a week for the parcel to arrive.
I confirm for my suito the problem is now resolved and I'm enjoying again :D
