Hi there,
I do have Nova force 8 and an Misuro B+, I am wondering how many led blinks I do have to setup? I read sometime 1 or 12 which one is correct?
I am using a 700 / 28c tire and would like to use the zwift app. Someone know how to set it up in the right way?
Thank you and appreciate your help.
Misuro B+ and Nova Force 8
Re: Misuro B+ and Nova Force 8
One flash is the correct setting.
You don't have to set a circumference value as the speed is calculated on the roller rotations (not on wheel rotation)
kreutzer.daniel
Oh OK thank you.
This means I do not have to chose the wheel size I need to chose the circumference of the roller?
Where can I find the circumference of the roller?
Thank you very much
Thank you very much
Our app and software automatically set it, so you don't have to insert it.
danieboerger
I have the same problem here.
My Misuro B+ will not connect to the app, even though it is set to one flash. I connect the home trainer, select bluetooth and begin to pedal, but nothing happens, not even after 5 minutes of pedaling. I tried it with my iPhone and iPad, even disconnected all other bluetooth-devices. Nothing. iPhone is an iPhone 7 on iOS 14.3, iPad 6. generation with iPadOS 14.4. What could be wrong?
The Misuro isn't even visible as a device in the phones bluetooth setting.
Thanks in advance,
best wishes,
Daniela
Thanks in advance,
best wishes,
Daniela
Same problem here. No signs of connection. Is there any support we can contact?
hug.deiber
I have the same probleme too
If you cannot connect with the misuro:
- check the number of flashes set in the misuro
- check the position of the misuro (orientation is important)
- check the battery charge level
Also, if you connect using bluetooth on a smartphone/tablet:
- check to have both bluetooth and position (gps/localization) active
If you can't connect using a pc/Mac:
- open the bluetooth menu of the pc
- check if the trainer is paired on the menu
- if it is so, unpair it!
- run my e-training
If still you're having issues, contact the customer care at info@elite-it.com
- run my e-training
