Displaying left and right pedal power on Garmin 520 Plus
Is there a way to display the left and right pedal power balance on my Garmin 520 Plus. There are settings to choose left and right power balance, but nothing comes up.
Re: Displaying left and right pedal power on Garmin 520 Plus
If you use our wired cadence sensor, you should see a percentage that refers to the right leg.
If you don't have the cadence sensor, you will see the percentage but you won't know if it is the right or left one.
So if you have the wired cadence sensor you'll get left and right leg power ?
Where can one purchase the wired sensor ?
Re-activating this post...
How do you activate this metric. I have it on my Garmin 530 on the indoor setting and it’s blank.
