I have a Direto X base trainer. when doing a calibration with E trainer, based on the sticker under the trainer, i should have an offset of 6457 but i'm at 6459. Is that a problem or it's ok?
Thanks for your help
Direto X calibration question
Re: Direto X calibration question
Are you sure to have done the 10 minutes training before running the calibration?
Anyway 2 points of difference are not much. So it's not a problem.
HI,
Yes, i did the 10 minutes training first. Even after doing a 3 hour ride, i still have the same results with just 2 points difference.
