Direto Broken Belt
andylinquist
Direto Broken Belt
Postby andylinquist » Sun Apr 14, 2019 5:42 pm
My belt broke today in the middle of a ride. It was working normally then suddenly lost resistance completely. I could see that the belt was broken through the vents. How is this issue handled? Will I need to send it in or will they send me a new belt? And if it’s the latter, how would it ever be accurate again?
Re: Direto Broken Belt
Postby Elite Admin S » Tue Apr 16, 2019 10:37 am
Contact the customer care at myetraining@elite-it.com.
The guys there will send you a new belt and pulley, and all the instructions to mount it and calibrate the trainer
marcelo.moreira.xavier
Postby marcelo.moreira.xavier » Wed Mar 25, 2020 3:10 pm
Hi andylinquist,
The belt replacement really solved the problem? Is this a reliable unit again?
I would appreciate your impressions.. I'm facing the same problem now.
Johny32
Postby Johny32 » Sun Apr 19, 2020 12:01 pm
Good morning,
The belt of my trainer also broke.
Anyone has or knows any distribuitor or store that sells the replacement belt for Elite Direto?
Edit: Due to be in the guarentee period, Elite solve my problem very quickly. In just 1 week (since i wrote the first mail till i receive the new kit (Belt replacement Kit for Direto) my problem was completely solved.
