Digital Qubo Wireless
Gshanley
Re: Digital Qubo Wireless
Postby Gshanley » Wed Apr 03, 2019 8:07 pm
I have a qubo wireless digital turbo. It was an newer upgraded model to replace a older faulty model.
Serial number is Q10076. Can I upgrade to use Zwift etc
andiyatsia
Postby andiyatsia » Sat Sep 14, 2019 1:15 am
carstenlotte wrote:Same question , serial number is SN: Q 14209
If your SN is 0340 is not upgradable (are you sure you didn xender discord omegle 't miss a digit? Serial number should have 5 digits)
nirvanausual
Postby nirvanausual » Thu May 28, 2020 2:40 pm
Zwift tells the trainer what the resistance should be at any given moment, you just have to keep those pedals spinning.
