I am having problems exporting sessions from myETraining to trainingpeaks via Trainingpeaks direct upload.
It fails every time I try, then I disconnect and reconnect to my trainingpeaks and I am able to export. Then next time I open the app and wants to export it fails again, and I need to do the disconnect/reconnect to make it work.
This happens both on my tablet (Samsung galaxy Tab A that controls my Elite Drivo) and on my Oneplus 3 phone.
Anyone that have the same issue, and have found a solution??
Exporting to trainingpeaks
Re: Exporting to trainingpeaks
If you export a tcx file instead, and then import it on TrainingPeaks, all works properly?
Anyway, contact our customer care at myetraining@elite-it.com explaining the situation and adding the tcx file you're importing.
martinfinnemann
Doing a manuel import/export the way you describe with .tcx files works fine.
It also works if I disconnect the myEtraining and trainingPeaks under my profile, and then reconnect it. Then I can upload directly. But a few days after when I want to upload again I have to do the disconnect/reconnect procedure again to be able to upload directly.
It is every time I have done a training, and want to upload to trainingpeaks that I have to do the disconnect/reconnect procedure.
nathjoye23
J'ai acheté un home trainer élite turno smart+.
Lorsque je l'ai couplé avec mon garmin edge 1000, les valeurs de la vitesse étaient complètement erronées, j'avais des valeurs de 200km/h, puis 2 secondes après 80km/h??
Alors que je pédalais à un rythme régulier, les valeurs de la cadence changeaient sans arrêt.
Comment puis je solutionner ce problème ?
Merci d'avance pour votre aide.
Nathalie
Nathalie
