Hi Guys,
I have just received my new Elite Turbo Muin Smart B+ trainer and I am having issues getting data out.
I am trying to pair it with a samsung Tablet and i can see the misuro in the bluetooth devices but when i try to connect i get the message "the misuro rejected the connection" (or something similar).
I have set up my misuro on setting 12 and it is installed correctly in the trainer.
Please help.
Mark
new misuro b+ wont pair
Re: new misuro b+ wont pair
Hi!
You don't have to do the pairing from the bluetooth menu of your device, otherwise you'll get a reject message. Simply run the app (my e-training or Zwift or whatever you're using) and do the configuration. The app will manage the connection by its own
Let me know if your able to connect
thanks for the update. This is what I thought was the problem. I did try to just do a simple training session in my e-training app and the devices still wont connect and I cant get any data from the device. I have another post open re invalid serial number and maybe the 2 issues are related.
It could be, as if the serial number is wrong, the trainer cannot be connected.
I've answered you in the other post
Did you get a reply from this. I can only see the misuro b+ if I press the button inside. Otherwise my Garmin and android phone refuse to see it.
When they do...no data comes back. I checked the battery with a volt meter...3v and I can see the device...but...no data...my heart rate monitor is working, but not this...
Firmware 11
331117c
Attached to eline turbo murine.
Is mine faulty?
Firmware 11
331117c
Is mine faulty?
The misuro goes in stand-by mode after some minutes. You can wake it up by pressing the button or simply by pedaling on the trainer (when the sensor sense the magnet, the misuro wakes up).
If the misuro doesn't wake up when you pedal (and also doesn't send data when you wake it up with the button) it means that probably the sensor and the magnet are not well aligned. To check this, please let me know which trainer do you have and also send a photo where I can see how the Misuro is positioned on the trainer (so I can check if it is in the correct position and direction)
Elite Admin S wrote:Hi!
You don't have to do the pairing from the bluetooth menu of your device, otherwise you'll get a reject message. Simply run the app (my e-training or Zwift or whatever you're using) and do the configuration. The app will manage the connection by its own![]()
The app is installed and there is no link to the Misuro b+ device. There is no setup in the app that allows for connection. Poor advice chaps!!
Do all the configuration steps and you'll be able to connect (if all is set properly)
I have a Qubo Power Mag digital plus. I have used it before no problems at all last winter. I have ome to use it again and it won't send data or detect pedaling. I can pair the device in the elite app but starting a training it won't send data. I have a new phone but I can't imagine that's the problem? please help!
I am having a similar issue.
Have the Elite Turbo Muin Smart B+ trainer with the Bluetooth Misuro sensor.
This morning I could see the trainer via Bluetooth on the Trainer Road app but couldn't get any data sent from trainer to TR app (cadence, speed, power) just stayed at 0 while peddling. I also put in a brand new battery and within 10 minutes it went from 100% to 0%. I tried a second battery and the exact same issue.
Not sure if this is related but I am wondering if the sensors are faulty.
