I have a Medisana bluetooth HR belt. I connected this belt to both iPhone and my iPad and is recognised by the iPad but i am not able to connect to the My E-training App. I tried to connect via the advanced settings option. In the health app from Apple my hartrate is visible.
According to the producer technical info the HR belt is compatible with: Apple iPhone 3 and higher, iPad 3 and higher, Strava, Wahoo, Endomondo, Polar, Suunto and more. It works with bluetooth 4.0/smart. Can you please advice
Connecting bluetooth HR belt
Re: Connecting bluetooth HR belt
It should work without problems.
Please contact our customer care using the contact form in the app, so we will receive additional information about your device
rene.farenhorst
thank you for your reply. I already found the answer in your old forum. I removed the program totally and re-installed it. After doing this I used the advanced mode and connected the HR belt.
