How can I create a map (route) by choosing points on the roads with my e-training app?
or
Is it possible to import a route from Strava to my e-training app?
Thanks...
Create Map (Route) for Training
Re: Create Map (Route) for Training
To create a Map route from e-training app:
go to Map Courses
Click the "+" sign located in the upper right corner of the screeen,
Select Create Map
Name: Something that will give you a reference for future use
From: Here try to type something that google maps can understand, because this info will be used to place the start pf the route (you can move it, but it will help a lot)
To: Same as above the the final point of the route
Notes: If you type (from and to) something that google maps dont recognizes, the system will tell you "Unable to create map!"
So type something very simple that works as a reference. you will move it later
Hope it helps!
if you keep getting error, or the map opens without initial start/end point, try putting an other "generic" name to the course
go to Map Courses
Select Create Map
Hope it helps!
christian011084
I have a problem saving the map.
I can create a map though, but if I want to save the map, nothing happens...
Maybe it has something to do with the height profile. When I create the map, I can not look at the height profile also.
so what can i do next?
Thanks in advance!
Thanks in advance!
ivan.skacokov
Hi. I have the same problem hire. I can create a route but when I try to save it one turning circle appears for a while and dat’s it – no file is save. The same is happened when I try to update the altitude – no altitude is shown Please tell me what is wrong. I use Android 9.0 and My E-training 2.8.0
Thank You in advance.
Hello guys,,
I have the same problem saving the map.
I can create a map though, but if I want to save the map, nothing happens click here...
