I ca'nt work out how this is achieved . I only seem to be able to save information for one rider at a time .
extra user on app ?
roberthorrocks
extra user on app ?
The instructions on the app. says it can be used by more than one user . But that must mean entering different details (weight etc) for second user.
Re: extra user on app ?
First, you need to create the second user (if it is still not in our databases).
Run the app and logout. Then register a new user instead of login with yours. At the end, logout.
Login in the app with the first user (the one with the subscription), open the left menu and select Premium.
In the lower part select the add email address option and insert the second user mail address.
roberthorrocks
Thanks , i think i understand .
Rob
Thanks , it worked .
Rob
