Calibration
stepheneashley
Calibration
Ok so I have finally got all hooked up and did the ‘trainer calibration’ there is a small difference in what it says and the sticker. So do I need to go something. Second I have 700 x 25 tyres which I calculated as 2105 is that right? Finally I then went on calibration wizard and started pedalling keeping in between the red lines and following a 10 min warm up however I pedalled away for 20 mins and nothing happened so I aborted! Any ideas
Re: Calibration
Start a training before doing the calibration.
Speed is properly shown?
If it is so, exit the training and start again calibration.
If it still doesn't work, contact the customer care at myetraining@elite-it.com adding as much information as possible (software/app version, device used, trainer serial number, calibration value you got...)
Re: Calibration
1. After I completed the training test (approx. 30 minutes) I wanted to calibrate the Direto. When I start the calibibration from the ETrainer app on iOS, it says starts pedaling and after 2~3 seconds ‘stop pedaling’. I hardly make 2 or round rounds with my pedals. Then it says ‘waiting for results’, after which the app crashes
2. What value do I need to enter in the field FPT under parameters? Currently it says 0.
3. I have asked this question before in other topics but never got an answer. Where can I find the manual of the ETrainer app (in English!)?
Re: Calibration
Can you please help? Not being able to calibrate the Direto makes it pretty useless. The other day I was racing on FulGaz but the trainer didn’t adjust the resistance. Going from one problem to another problem with the Direto...
Re: Calibration
Thanks for your reply, email has been sent.
Users browsing this forum: Google [Bot] and 20 guests
