failure to calibrate
davidrich
Postby davidrich » Wed Sep 12, 2018 4:49 pm
Hi, I have been a bad user :( and have not regularly calibrated my Volano Smart Misuro B+. Now that the weather is changing and I'll start using the turbo again, I have tried to calibrate the trainer via the app on my phone (Samsung). It seems to be calibrating (round icon swirling round and round) but after about 4 or 5 minutes, it says 'calibration failed'. Any help on how I can calibrate successfully?? I assume that I should stop pedalling whilst the calibration is in progress.
Re: failure to calibrate
Postby Elite Admin S » Tue Sep 18, 2018 8:32 am
Hi David
Volano cannot be calibrated. The option should also not appear in the menu.
Are you sure that you've selected the correct trainer in the menu? Give it a check.
Return to “Misuro”
