Direto calibration value
Skyrunner39
Postby Skyrunner39 » Sun May 20, 2018 9:01 pm
I did a good 10 min warm up and followed the my elite ios app instructions and received a off set value of '6632' my trainers value as stated on the sticker underneath is '6636'
With those figures in mind is there any need for any kind of adjustment?
Re: Direto calibration value
Postby Elite Admin S » Mon May 21, 2018 9:00 am
Hi Skyrunner39
The value you're getting is still within the limits.
If it lowers more than this (less than 6630), contact the customer care at myetraining@elite-it.com (it may be necessary to tighten the belt).
Skyrunner39
Postby Skyrunner39 » Mon May 21, 2018 11:12 am
Thanks for the info.
:D
nicolobottazzi
Postby nicolobottazzi » Sat Sep 15, 2018 7:32 pm
Ciao
nello sticker sotto il mito direto ho il valore 6490 e dalla calibrazione risulta 6485, è meglio far registrare il mio direto o posso stare tranquillo.
grazie per il supproto
ciao
Postby Elite Admin S » Tue Sep 18, 2018 9:15 am
Nicola,
se non noti nessuna anomalia continua pure ad allenarti senza problemi.
Se invece dovessi notare slittamenti, abbassamento della potenza o rumori strani (o se dovesse calare ulteriormente il valore nelle prossime settimane), contattaci all'indirizzo myetraining@elite-it.com e valuteremo insieme se è il caso di stringere la cinghia.
tfpabudgie
Postby tfpabudgie » Sat Apr 03, 2021 10:10 am
When the trainer calibration value is 4 points different from the sticker value, how many watts does this cost? We are using Zwift.
Postby Elite Admin S » Tue Apr 06, 2021 10:36 am
With a small difference, there won't be any power difference.
The firmware will consider the difference in the offset to adjusts the power.
