Qubo Digital WT - Desktop
fedesupervielle
Postby fedesupervielle » Wed May 30, 2018 6:26 pm
I've been doing a lot of reading, in this forum, the official webpage, and everywhere on the Web, but I haven't found the information I'm looking for. I own a QUBO DIGITAL WT trainer. I have downloaded the desktop version of MY E TRAINING on my MacBook.
What else do I need?
According to the instructions that came with the trainer, it's compatible with the MISURO B+, but the QUBO DIGITAL WT does not appear on the webpage as one of the trainers compatible with the MISURO B+. Is it compatible? Do I need anything else? For example, a DONGLE USB ANT+ for the MacBook?
If the MISURO B+ is not compatible with my trainer, is there any other way of using the app with my trainer?
Many thanks in advance.
Re: Qubo Digital WT - Desktop
Postby Elite Admin S » Thu May 31, 2018 8:39 am
I confirm you that Qubo Digital WT is compatible with misuro B+.
With the misuro sensor, you'll be able to connect it to my e-training Desktop on your mac.
Please notice that you have to install the beta version of the software, as the official one doesn't support the smart trainers (only the interactive ones).
To install it:
- go to this page: http://www.elite-it.com/en/products/glo ... e-training
- click on "click to download"
- select "participate in the beta phase"
fedesupervielle
Postby fedesupervielle » Thu May 31, 2018 11:46 pm
Thank you very much. Will I need a USB ANT+ dongle?
Postby Elite Admin S » Mon Jun 04, 2018 8:35 am
It depends on your Mac.
If it supports the bluetooth LE, you'll be able to connect using bluetooth.
fedesupervielle
Postby fedesupervielle » Mon Jun 04, 2018 7:05 pm
Ok, many thanks again. Can't wait to try it out.
