I'm interested in the ELITE TURBO ROTEO FLUID SMART B+ DIRECT DRIVE TURBO TRAINER (Also called Volano Smart B+) direct fluid trainer. I'm unsure if the smart app changes the resistance to mimic a hill climbs. Does anyone have any experience of this trainer that can answer the question please?
Many thanks
Mark
chunkylump
Re: ELITE TURBO ROTEO FLUID SMART B+ DIRECT DRIVE TURBO TRAINER
Turbo Roteo is not an interactive trainer, so its resistance cannot be changed by the app.
good evening. I got one today. the whole facility went well. when I participated in the zwift I saw that the watts charged were double the real. compared to the GPS device that gave me the same zwift power rating. indicates that the smart trainer is de-calibrated. Is it possible to calibrate?
@saraiva_b,
I'm not sure to have understood what you mean.
Did you have a power meter that shows you half watts compared to the ones you get with Turno?
Or are you comparing your power to the power you'd have on a simulation?
In the first case, please write to the customer care at real@elite-it.com to analyze the data.
In the second case, if you have a Turno remember that it is NOT a simulator. Its power curve grows up very quickly, far more than what you'd have on an outdoor training. Please take a look at this document (it's about Turbo Muin, but the concept is the same):
