Do I have to take the power connection out and put it back in each time I want to use it? Seems a bit clumsy.
It doesn't wake up by just pedalling.
Turning Direto on / waking up - how?
Re: Turning Direto on / waking up - how?
The Direto goes in stand-by mode after 15 minutes of no-speed data incoming.
It should wake up by pedaling on it, if it doesn't is really strange (is the speed sensor that "wakes up" the trainer, and if it normally works, it must work also to exit from the stand by mode). Please contact our customer care at real@elite-it.com to investigate further.
Was this resolved as I have the same issue? When I want to calibrate the unit I have to unplug the unit for it to pick the trainer up even though It was connected seconds before to setup all the sensors in parameters.
