Did my Direto just break? Crank wouldn't turn then resistance inconsistent
cconely
Postby cconely » Sat Dec 23, 2017 10:20 pm
Did my Direto just break? I got on it to do a workout and it was pedaling fine, then the crank would barely turn, and now the resistance is really inconsistent and jerky. I tried adjusting the belt resistance to see if that might fix it, but it did not. Pedaling is jerky and there's a bit of a clicking noise coming from the trainer.
dwanderson
Re: Did my Direto just break? Crank wouldn't turn then resistance inconsistent
Postby dwanderson » Sun Dec 24, 2017 12:17 am
I am having the same issue. It just started today. Have you heard of any fixes for this?
Thanks,
don
robford@icloud.com
Postby robford@icloud.com » Fri Jan 05, 2018 8:31 pm
Did you get this sorted out? I had a very similar issue on my Direto but in my case the drive belt turned itself inside out and came off. I refitting and tensioned it but after 10 days of normal use, this evening the drive belt snapped.
Postby Elite Admin S » Thu Jan 25, 2018 10:52 am
Guys,
it is clearly an hardware issue. Please contact the customer care at real@elite-it.com and specify the serial number of the trainer
