Justo Update Vers. 20 failed
mymiherrmann@gmx.de
Postby mymiherrmann@gmx.de » Sat Jan 25, 2025 10:27 am
my Justo does not work any more after the update to vers. 20. Heartrate and Aria works fine but the trainer does not connect or indicates approx. 4 times more power.
red led: permanent
blue led: permanent or flashing
green led: flashing
upgrado app indicates everything ok and version 20 installed.
I was happy with the vers. 9 and the trainer worked super - now I can not use the trainer any more.
Youre immediate help will be highly appreciated.
Regards, Michael
mymiherrmann@gmx.de
Re: Justo Update Vers. 20 failed
Postby mymiherrmann@gmx.de » Tue Feb 04, 2025 10:06 am
Once conducting the re-calibration the trainer worked again w/o any issue.
Return to “Justo”
