Firmware 87 rev 5
sottole3
Firmware 87 rev 5
Postby sottole3 » Mon Dec 09, 2024 4:46 pm
Buongiorno,
oggi ho scaricato l'ultima versione del FW per questo rullo e mi aspettavo di vederlo finalmente compatibile con Zwift Cog & Click ma non sono riuscito a individuare questa funzione attiva su Zwift. Mi sono perso qualche settaggio oppure l'aggiornamento non lo prevede?
steve.hammatt
Re: Firmware 87 rev 5
Postby steve.hammatt » Tue Dec 10, 2024 9:35 am
Others on the Zwift forums have reported successfully using firmware 87 to connect a Zwift Ride. Are you connecting your training over Bluetooth? Because virtual shifting does not work over ANT+.
sottole3
Postby sottole3 » Tue Dec 10, 2024 3:04 pm
Thanks for your answer.
Yes, I know, but I don't figure out why Click is recognized by Companion App and not in PC Win 11 although it shows in BT devices in the Control Panel. I installed latest Zwift Version 1.79 and I don't see any virtual shifting neither Control
gciocia
Postby gciocia » Tue Dec 10, 2024 5:59 pm
When race mode (10hz) will be available for direto xr?
Are there any improvements in erg management in this latest firmware?
appjerezsur
Postby appjerezsur » Tue Dec 10, 2024 6:10 pm
sottole3 wrote:Thanks for your answer.
yo tengo windosws 11 y funciona correctamente, revisa la version de tu bluetooth por si acaso, yo ten la 5.4
appjerezsur
Postby appjerezsur » Tue Dec 10, 2024 6:36 pm
En la web de ELITE ofrecen un descuento de 20€ por comprar el ZWIFT COG
https://www.elite-it.com/en/news/direto ... g-on-zwift
Tambien explica un poco lo de la actualizacion
sottole3
Postby sottole3 » Tue Dec 10, 2024 8:05 pm
appjerezsur wrote:yo tengo windosws 11 y funciona correctamente, revisa la version de tu bluetooth por si acaso, yo ten la 5.4
I have 5.0 BT version but now I try to change the device. I suppose this is the reason of the issue.
Update. I used a new BT Dongle 5.3 and a new PC but remain the same problem. Zwift Click shows in Companion but not in Zwift Ride :x
pizzii
Postby pizzii » Sat Dec 14, 2024 7:25 pm
As far as I can tell, after a long time and several attempts (iPhone 6, Pixel 5, iPhone 15), I finally succeeded to see the Zwift Clicker interaction with the Direto XR-T trainer only after I connected it in the Zwift Companion and immediately, attempted to ride in Zwift, after I added it in the Controller menu. I first needed to press the ERG secondary menu button (shows as blue buttons after you touch the phone screen), in order to allow the gear number to display. In some rides the gear number shows in the left top corner besides other bike movement measurements (or maybe it depends on the phone screen size, yet to figure out).
Overall, Zwift ride simulations give an imprecise slope difficulty feeling, most of the time had to use gear 24, although it would unexpectedly feel like I need to get down to gear 20. On another test ride explicitly involving climbing all the way to more than 8-10% slopes it gave a better feedback and had to switch down all the way to gear 5-7... but I still feel it's rather imprecise in feedback behavior.
I still wonder if the Clicker is expected to be used with the myETraining app real videos, given the Elite Direto XR-T firmware is updated, and advertised as: "[...] can unlock compatibility with virtual shifting and almost any 8 to 12-speed bike, paired with premium features like a built-in power meter and advanced connectivity with sensors and devices"
steve.hammatt
Postby steve.hammatt » Sun Dec 15, 2024 9:41 am
Virtual shifting only works with Zwift. I'd be very susrprised if you could use it witnin myEtraining.
pizzii
Postby pizzii » Sun Dec 15, 2024 5:23 pm
Virtual shifting only works with Zwift. I'd be very surprised if you could use it witnin myEtraining.
Yeah, you're very likely right, Steve, but it's still quite annoying the imprecision and vagueness of documentation on the Elite website. It's also quite a turn-off how they provide blank wide statements on the capabilities of the new firmware (feels like aiming to even leave up to interpretation how compatible is expected to be), while there's no explicit documentation anywhere on how's this new featured compatibility expected to be configured and experienced and more importantly where... Quite a disappointment so far. I remain optimistic that customer pressure might make them understand the shortcomings :roll: ... Dear admins, any thoughts on documentation improvement? :)
