Problem with mounting thruaxle
konradgalazka
Postby konradgalazka » Tue Dec 05, 2023 11:55 am
Hello, I have a problem with mounting my Lapierre Crosshill gravel bike to Suito trainter.
I have bought all needed adapters, including the thruaxle boost adapter. The problem is that when I mount the bike there is no space between casette locking ring and frame. Seems like the issue is caused by slightly hollowed rear deraileur hanger which consumes few milimeters of space.
Here is the photo of my problem:
Did anyone have similar problem and solved it? I have searched for solution but did not find any. Also have checked if all elements are in right place so it seems everything is fine.
Thank you in advance.
Return to “Suito”
Users browsing this forum: No registered users and 45 guests
