Problem with NX Eagle 12s casette on Direto XR-T
sirmicho
Postby sirmicho » Sun Oct 29, 2023 8:04 am
Hi. I just bought Direto XR-T and I'm having problems installing the SRAM NX Eagle 12 speed casette. I'm a bit confused to be honest. No matter how I install the casette (with or without included spacers) it's wobbly and not sitting firm. I started to search for the solution and found there is a SHIMANO FREEHUB WITH MICROSPLINE code no 1014315. Manual to my Elite Dirteto XR-T states that I have freehunb code no 6014229 so it's a freehub for road bike casettes, although I'm pretty sure my casette should work with this freehub. I was convinced before the purchase that this trainer comes with a NX Eagle 12s compatible freehub according to a pdf on Elite's website. So what's going on here? Please help.
sirmicho
Re: Problem with NX Eagle 12s casette on Direto XR-T
Postby sirmicho » Tue Oct 31, 2023 7:27 am
Problem solved. I had to install 1,85 mm spacer beneath the cassette. For some reason spacers included in the package didn't work. Also a tip to Elite company - please update your manual to include information about Sram NX Eagle 12s cassette compatibility and how to install it. There is no mention of this cassette whatsoever in the manual which is a shame and it is very confusing.
Users browsing this forum: Bing [Bot] and 42 guests
