For a couple of weeks I have been noticing how every time I connect my DIRETO XR trainer it makes a strange noise, as if two metal pieces were rubbing together.
This noise remains during training when I develop a low power, around 80-100W.
This noise is increasingly annoying and I would like to know how to solve this problem.
I am attaching a link to youtube where you can see a video of the type of noise it makes when plugged in.
https://youtu.be/Czj4AWhCLBo
I have tried to put a ticket to the support center, but surprisingly the service is not available. This makes me really disappointed with the after sales service.
Annoying noise when connecting DIRETO XR
Re: Annoying noise when connecting DIRETO XR
I seem to have the exact same noise when starting up. When pedalling the hose is also present, disappearing after 5-10 minuten on higher cadence.
anco wrote:I seem to have the exact same noise when starting up. When pedalling the hose is also present, disappearing after 5-10 minuten on higher cadence.
Something similar happens to me, but if I stop pedaling and the wheel is free, a very annoying metallic noise sounds. I think that sooner or later the roller will end up breaking.
I don't understand how a company like this can leave the consumer without a solution. I have been trying to file a ticket for more than a week to see how to solve the problem and the customer service is still disabled.
It is probably necessary to add some grease to the motor screw:
https://elitesrl.zendesk.com/hc/en-us/a ... ew-thread-
I also checked the support land page and it is working:
But if you have any problem, you can also write to this address:
info@elite-it.com
info@elite-it.com
Elite Admin S wrote:It is probably necessary to add some grease to the motor screw:
In this article, the first thing I come across is a warning that I lose my warranty if I don't have the authorization to handle the roller from customer service.
surrfero wrote:I also checked the support land page and it is working:
The website works but the service doesn't. When I fill out the form and want to send it, a message appears indicating that the service is not available.
How am I going to get authorization if I can't even contact customer service?
This is strange.
May I ask you in which country you live exactly?
In the meanwhile, contact the support using this mail address:
info@elite-it.com
info@elite-it.com
Elite Admin S wrote:In the meanwhile, contact the support using this mail address:
info@elite-it.com
I have managed to contact customer service and now have written authorization to open the trainer.
Thank you.
surrfero wrote:I have managed to contact customer service and now have written authorization to open the trainer. crossover grid
Thank you.
Have they responded yet?
tonyadams wrote:surrfero wrote:I have managed to contact customer service and now have written authorization to open the trainer gorilla tag
When connecting DIRETO XR I also encountered the same situation as you, I contacted and received help
