Loose sprockets on 11 speed 105' 11-34 (Elite Suito)
dj.antaro
Postby dj.antaro » Mon Oct 17, 2022 9:41 am
please help with an issue im having. I've bught new Elite Suito trainer for my girlfriend, Quick Release set up system, Cassette Shimano 105 R7000 11-34t and According to user manual i don't have to put a spacer for this set up. Well, i haven't, and i noticed a big loose moving space between 10 and 11th sprocket. What's going on?
When i put 1 spacer, as for 10speed, everything is tight and ok.
Re: Loose sprockets on 11 speed 105' 11-34 (Elite Suito)
Postby Elite Admin S » Tue Oct 25, 2022 9:23 am
Usually it's not necessary to add a spacer with 11 speed cassettes, but It may happen as not all the bikes have the same measures.
So, keep using the extra spacer
mjv144
Postby mjv144 » Sun Jan 08, 2023 11:14 pm
I just installed an 11-34 cassette to my Suito-T using a spacer. According to Shimano, the HG800 11-34 cassette is essentially a mountain bike cassette so a spacer is needed when installing to a road hub. Everything seems tight without any loose sprockets. Would like a confirmation from Elite though.
tryarena
Postby tryarena » Mon May 08, 2023 8:41 am
mjv144 wrote:I just installed an 11-34 cassette to my Suito-T using a spacer. According to Shimano, the HG800 11-34 cassette is essentially a mountain bike cassette so a spacer is needed when installing to a road hub. Everything seems tight without any loose sprockets. Would like a confirmation from Elite though. a small world cup
that's great.
florencepugh
Postby florencepugh » Mon Jun 26, 2023 9:39 am
I suggest inserting a spacer for a 10-speed cassette which can give a snug fit and cure the problem. fnf
Return to “Suito”
