Just brought a Suito-T and been having trouble installing my Crank based PM which is a 4iii dual sided.
I have tried using the power meter link but only recognises one side of the power meter.
Does any one know if it’s possible to use 4iii with the trainer has a PM?
4iii dual sided Power meter
Re: 4iii dual sided Power meter
In my e-training, in the PML section, you have to select the "Half Power" option
t.garlinge
Does that mean you are only reading off one side and not dual side PM?
