So I found out that it was the freehub that was broken, on my Direto XR. I'm looking for a spare part, the only one I found on the website - shopelite-it.com is:
https://www.shopelite-it.com/en/spare-p ... le-version
Will this one work on my Direto XR ? (Quick Release, Shimano 11 speeds)
Regards.
Spare parts: is this one compatible ?
steve.hammatt
Re: Spare parts: is this one compatible ?
Nope.
As mentioned in my post, I'm looking for no thru axle version.
Or to make it more clear: I need to replace the one that was installed by default on the Direto XR.
This is the correct one (the same indicated by Steve):
https://www.shopelite-it.com/en/spare-p ... metrainers
OK. So, it's not available right now :-\
