Looks like I'm not alone in trying to get data to display.
I have a TravelTrac Smart B+ Misuro and Garmin Edge 830 and would love to see data on my Garmin. The Misuro B+ IS paired with my Garmin, my Garmin cadence, and speed sensors are seen.
I've replaced the battery
I've moved the sensor around
I've removed and replaced all sensors including the Misuro
I've tested it by turning the crank manually for at least 5 minutes
I've tested it by sitting on the bike and riding for another 10 minutes
I've not ever had this much difficulty with a Smart trainer. Did I purchase a massive paperweight?
What am I missing?
Any help would be greatly appreciated before I throw this thing out.
Re: TravelTrac Smart B+ Misuro and Garmin Edge 830
Played with the placement of the sensor. I FINALLY got it right.
All good.
Thanks!
All good.
Thanks!
simone.saresin
Hello
I got the same problem with Garmin Edge 530.
What do you mean with "Played with the placement of the sensor. I FINALLY got it right." ?
You found a different position for the Misuto B+ ?
I placed it according to the manual of Elite Qubo Mag.
I need move it to a different position ?
Thank you
Thank you
