There is an awful noise coming from my trainer when I'm pedaling . I've calibrated it and it is level on a trainer specific mat. Any suggestions please?
https://imgur.com/a/A0ouiYO
Awful noise coming from my Direto XR
Re: Awful noise coming from my Direto XR
Please contact our customer care. Specify the trainer model, serial number and add the link of the video:
Thanks I have done that.
I had the same sound after 2 winter use, I had to tighten the screw on the flywheel inside, now the sound is quiet perfect.
garciapresa
Hi! Have you fixed the problem?
Thanks!!
Thanks!!
J'ai aussi ce bruit similaire serait il pas à cause des roulement du volant le miens date de 2020
Avez vous résolu le bruit si oui comment procéder
Bien sportivement
Bien sportivement
jeffreestar
Check your bike for any loose components that might be causing the noise. Pay particular attention to the pedals, chainring, chain, and rear cassette. that's not my neighbor
