Suito-T - Calibration with myETraining
david.edery
Postby david.edery » Tue Mar 01, 2022 6:58 pm
Tried to calibrate the trainer using myETraining app (latest FW, upgraded using Upgrado).
App asked to increase the speed, reached more than 50Km/h and it continued to ask me to increase the speed...
Didn't manage to calibrate.
What am I/the app is doing wrong and how can this be fixed?
Thanks,
David.
red.hell
Re: Suito-T - Calibration with myETraining
Postby red.hell » Tue Mar 01, 2022 8:06 pm
hi, connect to suito with only one device -for example no app on smartphone + garmin- and try to remove all other devices around that use bluetooth or wifi
david.edery
Postby david.edery » Wed Mar 02, 2022 8:04 am
Only one device is connected to the trainer (in this case, the phone, through BT)
Postby Elite Admin S » Wed Mar 02, 2022 8:39 am
Try to uninstall the app and install it again.
Try also using a different device
david.edery
Postby david.edery » Wed Mar 02, 2022 6:39 pm
What do you mean by "try to use a different device"? Do the calibration via my garmin watch? (and not the app)
angel.jp1
Postby angel.jp1 » Fri Sep 02, 2022 6:31 pm
Buenas tardes igualmente tengo problemas con la calibración la velocidad que pide llega a 10km/h y no sube de eso en el entrenamiento.
Postby Elite Admin S » Mon Sep 05, 2022 8:32 am
Hola Angel
Estas seguro de haber inserido el correcto valor de circumferencia?
Si pedalea normalmente en cualquier entrenamiento, la velocidad esta correcta?
Si es asì, por favor deinstala la app y instalala de nuevo.
Si el problema no desaparece, contacta la asistencia tecnica:
Un saludo
Return to “Suito”
Users browsing this forum: No registered users and 37 guests
