Suito RH bearing issue, belt contact
rod975
Postby rod975 » Mon Mar 14, 2022 3:41 pm
My Suito has developed a lean to the right and the belt makes contact and buzzes somewhere inside the main housing. I am assuming the RH bearing is failing. Can I order a bearing and the plastic spacers or can I get the spec on the bearing so I can replace it. Thanks
Return to “Suito”
Users browsing this forum: No registered users and 45 guests
